Are these 73 Heads? - NCRS Discussion Boards
Are these 73 Heads?
  • Calvin C.
    • May 31, 2002
    • 240
    Are these 73 Heads?
    I have a 73 454 convertible, it has a 1969 passenger 427 block, about 300 horse. The engine runs smooth can drive it the trans is shot. The carb and intake are corectly dated and number for the car. I just checked the head numbers and they are
    (358049) dated (1 21 72), this could be a line then 2 a line then 72, (GM8t) and the word (Pass)
    Are these the correct heads and how will they work with a 1969 300 horse 427. Any idea of port or compression ratios
    thanks
    cal
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Are these 73 Heads?
    are you sure the # is not 353049 which are 73/84 454,122 cc chambers,255/119 cc ports
    • Clem Z.
      • January 1, 2006
      • 9427
      your CR will be low as your 427 engine
      should have 96.4 cc heads. i have seen 2 different specs for the chamber volume of the 353049 heads,122 and 113 cc.
      • Calvin C.
        • May 31, 2002
        • 240
        Clem
        I thought I copied it down corect but I am sure it is most likely is 353049
        thanks
        cal
        • Calvin C.
          • May 31, 2002
          • 240
          Re: your CR will be low as your 427 engine
          Clem
          So, If the 427 was a low horse power to begin with, say 290 horse or so, then the 454 heads will be lower?
          Cal
          • Clem Z.
            • January 1, 2006
            • 9427
            the lowest HP 427 in 1969 was 335 HP and the
            lower CR because of the 454 heads with bigger chambers will kill some HP and torque
