I recently had my 69 repainted and there were rusted metal rivets pushing up the fiberglass from the front support surround(the metal support under the fiberglass by the horns) which I have seen on many Corvettes. The body shop ground out the fiberglass and replaced the rivets. Once the rivets were replaced they fiberglassed in the holes. You can now see the area where they reglassed over the rivets. It looks like the fiberglass shrunk and there is now a slight indentation. I spoke with the body shop guy and now he tells me the only way to fix it is to remove the entire support and fiberglass in in rather than using rivets. Anyone have this same problem and what was the solution? This sound rather complicated and I'm concerned about causing more problems.
