69 horn and vacuum canister bolt headmarks - NCRS Discussion Boards
  • kelly theaker
    the bolt headmarks for the 2 horn bolts and the 6 bolts that hold the vacuum tank on the drivers fender well should be ?
    Re: 69 horn and vacuum canister bolt headmarks
    kelly-----
    The horn bolts are 5/16" bolts (1/2" across the flats) and have an "E" in a circle with 3 lines 90 degrees apart (GM 275-M).
    The vacuum tank bolts are 1/4" bolts (3/8" across-the-flats) and also have an "E" with 3 lines 90 degrees apart (GM 275-M). For these bolts, there is no circle around the "E".
    These are the configuration of some bolts that were originally used. Other bolt head markings may have been used, too.
