I seem to be having a problem with the choke on my 60. Sometimes on cold start up the choke and high idle do not engage. I have removed the choke housing to insure all is well within and checked the linkages to insure there is no binding. I then set the stove spring per the service manual instructions and even increased the spring tension by adjusting one more notch richer than the instructions call for and I am still have intermittant problems. The choke seems to set with regularity when the air cleaner ( current correct repro) is not installed. I have noticed that the a/c base has a number of dished locations I assume to allow for clearance of the choke linkages and the front vent cap.One of these dished areas is much larger than the others, yet there is no index mark for the correct install location. Could the a/c base not being installed in the correct location interfear with the operation of the choke valve/linkage? Could someone tell me what the correct orientaion of the a/c base is. Thanks as always!
Don
Don
