Fan Clutch for 65 Fuel Injection Vette - NCRS Discussion Boards
  • Floyd Dossey
    I have the original fan clutch for my 65 Fuelie, how can I tell if the fan clutch is bad or not? Thanks in Advance Floyd
  • Roger Coen
    Re: Fan Clutch for 65 Fuel Injection Vette
    When the engine is throughly warmed up see if tge fan turns easily. If it does, you probley need a new/rebuilt one. Only person I know that rebuilds is Fred Oliva in FLA. foliva@gate.net
    Roger
    • Roger Coen
      Roger
      • Fred Oliva
        As Roger states, start the engine & warm it up to normal operating temperature. Then, with the engine at idle, shut the engine down & observe the fan. The fan should stop within 3 revolutions of the engine stopping.
        Failing usually will freewheel for many revolutions. There will be no 'middle ground' so to speak. It will either windmill like crazy or will stop within 3 turns.
        Hope this helps.
        Fred Oliva
        • Fred Oliva
          Hope this helps.
          Fred Oliva
          • Floyd Dossey
            Roger and Fred Thanks for the information, I will do as you suggest and see what happens. Thanks again. Floyd
            • Floyd Dossey
