First Start on 62 - NCRS Discussion Boards
First Start on 62
  • John L.
    • February 1, 1982
    • 35
    First Start on 62
    After 4 long years of restoration I finally started my 300 HP 62 today. It lit off on the first crank and surprisingly the timing set statically was almost right on. The only problem was that the thermostat never opened and I had to shut it down. The upper hose didn't get warm. Before I started it I removed the thermostat, filled the block with water and reinstalled the thermostat. I also filled the expansion tank which did get hot. I'll check out the thermostat tomorrow in a pot on the stove, but assuming it tests ok, any other ideas??
  • Mike M.
    • May 31, 1974
    • 8365
    Re: First Start on 62
    you don't mention the opening temp of the thermostat you installed. the upper rad hose won't get hot to touch until the engine reaches X degrees(x being the opening temp of the thermostat) once the thermo.opens, coolant will flow thru rad thru thermo and back into engine. don't rely on C-1 temp guage/ sending unit accuracy till you've checked operating temps with a more accurate device(digital pyrometer my favorite) as most c-1 temp readings are questionable till you've sorted out guage/ sending unit.
    • Brian Monticello
      John,
      I 2nd what mike said. Just this past weekend in 45 degree weather my 327/300 idled for 20 minutes w/o the thermostat opening and it's a 160 degree (relax....i'm changing it to 180). I thought the gauge might not be working but the upper hose was cool and not pressurized, and the engine wasn't scorching -- determined by the very scientific valve cover touch test.
      Brian
      • Jim T.
        • March 1, 1993
        • 5351
        John I sure hope you reinstalled the thermostat correctly after filling the block. You could drill a small hole in the thermostat to let the air burp after future drainings of the coolant.
        • Tracy C.
          • July 31, 2003
          • 2739
          Are you sure you didn't pull a "Crisler" and install the themostat upside down??
          This famous trick has a humbling effect...
          Everyone should try it at least once.
          tc
