1966 Big Block - NCRS Discussion Boards
1966 Big Block
  • Kirk Turner
    1966 Big Block
    Hi,
    New to the board, but a member for the past three years. I'm leaving tomorrow to look at a 1966 big block roadster (390/427). I need some info on what to look for to verify that it is an original BB. It is a NOM 390/427. I know about the sway bars, tach and oil pressure guage, but is there anything else that I can use to verify it's build?
    Kirk Turner
  • R N.
    • May 31, 2002
    • 640
    Re: 1966 Big Block
    Kirk:
    U-joints have caps with bolts on the half shafts
    RH mount for hood support.
    Others may know more. Good lunck.
    Kurt Neiman
    • Mike M.
      • May 31, 1974
      • 8365
      Re: 1966 Big Block
      core support and gas line from tank to fuel pump. Judging manual( i still can't refer to it as a J.G.) discusses these . mike
      • Kirk Turner
        Re: 1966 Big Block
        Mike,
        Don't have the judging manual for a 66 (do for 63,67,69). Could you be a little more specific. (can't get one by tomorrow either).
        Kirk
        • Mike M.
          • May 31, 1974
          • 8365
          Re: 1966 Big Block
          the 65 and 67 marrk 4 engines used the same main fuel line that a 66 bib block utilized. Basically, the overall length and the angle bent on the fuel pump end of the line differ from mall to big block fuel lines. mike
          • R N.
            • May 31, 2002
            • 640
            Re: 1966 Big Block
            Kirk:
            Sorry, it's LH mount for hood support.
            Kurt.
            • Pete Lovrovich
              Re: 1966 Big Block
              Kirk,
              The hood support for a big block 66 is located on the left side unless the VIN is approx. 3600 or before, it would then be located on the left side as a carry over from the 65 model.
              • Kirk Turner
                Re: 1966 Big Block
                Thank-you all for your help. Hopefully it is as nice a car as the gentleman has told me.
                Kirk
