If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
thinner shim brings inner and outer bearings CLOSER to their respective races, hence reducing end play.Once you've disassembled spindle, it'll become clearer. good luck, mike
The races are fixed in the bearing housing (not sure what that part is called). They face each other and are conical shaped. One bearing will be on the inside and one on the outside riding on the races. There will be one large spacer and one or maybe two thin spacers (can't remember). The spindle shaft slides through all this stuff and with a large washer and nut it is all held together. If you actually have it all apart and in good condition, give yourself a pat on the back. They typically don't just fall apart for you when you try to take them apart and a lot of times you need special tools to press the spindle out (digressing).
The spacers between the bearings are used to adjust the pre-load on the bearing surfaces. You can't just tighten up the assembly and call it good. There is a very minimal clearance that is required to keep the bearings healthy. Most people use a tool called a pre-load shaft that is slightly smaller in diameter to the spindle shaft (which has a press on clearance). You put the bearings in the housing with the spacers and install the pre-load shaft. I would probably clean and dry the bearings before doing this, use a very light oil on them. Next, you somehow attach a dial indicator two the shaft and measure the play (clearance) on the axis through the bearings (in line with the pre-load shaft). Do this over and over while adjusting the shims untill you get the right clearance. After you get the clearance, then assemble it with the actual spindle shaft which is a press fit. It has been years since I did this. Others can comment... It is critical to get it right and use good high pressure grease when it all goes back to gether. Regards, Terry
The part you refer to is called the spindle housing. The large spacer looks a lot like the "crush collar" used for the diff pinion bearing, but it does not crush, and is reusable if not galled. The other spacer is actually a ring of about 1 1/4" diameter, and thicknesses varying in .003" increments. These can be CAREFULLY shaved with emery, to really "tweak" the bearing end play. Got mine to .0005" (I know, the manual says .001"-.008.", but I always prefer my "thrusts" nice an' tight).
I did the same thing with the emery cloth. I figured I needed all the help I could get with the run out on the brake rotor. I thought it could have some effect there. I stopped at the .001 to .003 range. Like my bearings to stay cool and my grease to stay in! Terry
I saw it in one of the familiar catalogs.....not sure which one now. I thought that that was strange, too. I've got a box full of them.....all sizes, couple hundred maybe. I just grab and mike 'em. Like I said, I like to shave the last couple thou to get a minimal end play.
C2 and C3 are exactly the same with respect to rear spindle bearing set-up. Some earlier 63s may have a slip fit spindle/bearing set-up but, otherwise, everything is the same.
Yes, early 63s definitely had the slip fit spindle/bearing assemblies. The reason that I used the term "may have" is that while they once definitely had this set-up, the may have been retrofitted to the press fit by now. Some of the early 63s were retrofitted under warranty and others may have been changed since.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
