C1 door - NCRS Discussion Boards
C1 door
  • Dave Lantz
    C1 door
    When I bought my '57 the rear window guide was loose.The 2 bolts that hold it through the rear of the door have pulled through the fiberglass.The holes are slightly larger than the bolt heads.Someone had put washers under the bolt heads.What's the best way to repair? I am considering grinding a little glass off the inside of the door and adhering a thin piece of metal to the door and bolting through that.Does anyone have a better idea or will this work? Thanks,Dave
  • David Lyon
    Thanks, Mike
    Dave, I had the same problem on my '58 right door. The left was fine. I reconstructed the area with fiberglass and drilled new holes. I felt if that's the way it came from the factory, then the repair would work as long as I owned the car. Others more knowledgeable may have a different read.
    David
