Should the firewall grommets, one for the wiring & oil pressure line, as well as the one for the tach & speedometer cables have slits in them in order to insert the wiring, line and cables?
'67 FIREWALL GROMMETS
Re: '67 FIREWALL GROMMETS
Rob-----
You bet! Without the slits the grommets would have had to be formed around the cables, wires, etc. or the ends of the cables/wires would have had to be installed after insertion of the cables through the grommet. Believe me, they didn't get involved with things like that at the factory; slits in the grommets were much easier and didn't compromise one iota of functionality.In Appreciation of John Hinckley- Top
