1966 ENGINE NUMBERS - NCRS Discussion Boards
1966 ENGINE NUMBERS
  • Marc N.
    • August 31, 1998
    • 97
    1966 ENGINE NUMBERS
    have an engine with the following numbers....big number on the back of the engine is #3869942 with a "p" under it. the other numbers on the right front are TO62IIP, 6125474 PLEASE ANY MEMBER ADVISE,,,THANKS, MARC
  • Everett Ogilvie
    Re: 1966 ENGINE NUMBERS
    The 3869942 is the block casting number which appears to be correct for the TO62IIP, which is Tonowanda engine build plant, June 21, and the IP is the suffix for the 425 HP engine, L72 option. The 6125474 is the VIN derivative for the car the engine originally was installed in. Nice engine...
    Where is the car?
    • Everett Ogilvie
      Where is the car?
