Also Check...
Kurt, also check your heavy black frame ground wire from the negative post of the battery. I've replaced this on 2 of my cars due to it corroding where it's connected to the frame and under the floorboards out in the elements. Just because you have voltage to your buzzer and such, you may not have enough amperage through a bad connection to spin the starter. I went through exactly what you did with my '75 Corvette(even replaced the starter and battery)before the wife said "Hey, maybe it's the ground"!!! Guess what???
