I am in the process of restoring a 1961 270HP Corvette. I would like to determine what rear axel ratio I have. The JG states that the ratio is determined by a notch on a 1 1/2" metal tag that is located towards the front of the case at about 2-o'clock. This tag is present at the correct location and has a notch at about 1-o'clock. There are also numbers and letters that I believe to be the date code: E 3 1 and casting number 3789812 which is correct for a late 61. There is also a large P with a small hash mark that I believe stands for a positraction unit.
Thanks for any help!
Ray
Ray
