1957 steering box - NCRS Discussion Boards
1957 steering box
  • Mike Noguera
    1957 steering box
    ANY SUGGESTIONS ON WHO TO SEND MY 1957 STEERING BOX FOR RECONDITIONING AND DOES THE STEERING SHAFT/COLUMN STAY ATTACHED TO THE BOX.
    PREFERABLY SOMEONE ON THE WEST COAST AND VENTURA COUNTY WOULD BE GREAT!
    ALSO, I'M IN NEED OF A 1957 AUTOMATIC RADIATOR SINCE THE ONE I HAVE IS FOR A STANTDARD TRANSMISSION.
    I'M VERY PLEASED WITH YOUR SUGGESTIONS TO USE GARY STEERING FOR MY STEERING WHEEL- HE DID A GREAT JOB AND I HIGHLY RECOMMEND HIM.
    THANKS AGAIN,
    MIKE
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 1957 steering box
    Automatic and standard tran. radiators are all the same.
    • Mike M.
      • May 31, 1974
      • 8365
      Mike: roy is corrrect. if you want to make your 57 a powerglide, the cast iron powerglide appropriate for 57 vettes did not have an external cooler, hence, as roy notes, the radiator for a manual tranny 57 is identical to that of a powerglide.Your question raises the possibility that the tranny in the car now has an external cooler. f theat's the case, you need to do some home work on automatic trannys available in 57 vettes.mike
      • Theodore K.
        • December 1, 1985
        • 214
        Mike,
        I did my own a couple of years ago. There have been several articles in the restorer over the years. I got my kit from Dot Pro in Little Rock ARK but Mr. Harrington has retired. He told someone else to use this guy.
        Tom Reina
        Corvette Steering Service Inc.
        2215 Mullinax Drive
        Anderson, SC 29625
        (864) 287 9990
        I realize that you are on the other coast. BAck in 1995 there was a seminar on box rebuilding put on at the NCRS meet in Steamboat Springs. The guy giving the seminar was form California. His name was:
        Joe Calcagno
        Box 62
        Soquel,California 95073
        408-475-4442
        He worked on them I recall. I don't know if the contact info is okay or not as this was 8 years ago. I can scan and send the PDF file of the article from the seminar if you like. Send me an email and I will forward. email=tvonkampen@charter.net
        Yes, the steering column stays attached to the box. I think the whole kit cost about $500 when I did it.
        Good luck.
        Ted
          Joe's area code has changed - he's at (831) 475-4442, e-mail is rarecorvettes@aol.com .
