54 Vette Convertible Frame - NCRS Discussion Boards
  • Larry M.
    • December 1, 1988
    • 40
    Could someone please tell me how to adjust the convertible top frame for my 54 vette. Please indicate the measurements that the frame should be above the deck lid by the doors and other points. I just replaced my top pads and mohair weatherstrip and need some help. Please email or post here. Thank you for your help.
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 54 Vette Convertible Frame
    The only ajustments that can be made IF the soft top cover was installed WRONG is to move the rear EGG shape support where bolted to the body ( forward and back or up and down). This is done as you install the rear straps and pads and then the top cover with the WINDOWS in.There are no real measurements to give.A lot is determined on how your windshield SITS. If you have a sunkin dash or missing lower windshield rubber ( in or not ) and if the windshield which can be moved forward or back , you can see that there are a lot of factor's.Goood luck.
