mid year drive line and cast iron parts restoratio - NCRS Discussion Boards
  • John M.
    • January 1, 2000
    • 175
    Im looking for methods to restore mid year drive lines and cast Iron parts with out painting them, IE rearend housing, front spindles etc. THANKS John Meissinger
  • Rob A.
    • December 1, 1991
    • 2126
    Re: mid year drive line and cast iron parts restor
    Krylon satin clear has recently been recommended by several member for just this purpose. I recommend it also, it works great, especially here in southern California with the nice, dry weather. I've used it on both cast iron and steel with good results. I've left cast iron as well as steel parts I coated with it outside to test it and it holds up very well.
    • Bill W.
      • March 1, 1980
      • 2000
      After you clean your parts and get them the correct color ( cast susp. parts come in many different colors) you can soak them overnight in oil,greese,cosmoline,wax products. stp, almost any type of water repelling product the trick is letting it soak until its full. pull out let it drain, wipe clean and your good for long time. ..Bill
      • Eugene B.
        • May 31, 1988
        • 710
        John,
        For a natural, unpainted finish, my favorite product is Pre-Lube 6, from Quanta. Great on half-shafts, drive shafts, cast parts, parking brake cables, etc.
        I can't tell you how long it will keep the treated parts from rusting. Depends on too many factors. What I can say though, is you will definately like the finish.
        Gene
