Warning: Undefined array key 2157 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
What are the differences in 1969 3927186 heads? -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
I need to replace the heads on my wife's 1969 L-46 with the correct 3927186 heads. I find a lot of these heads off Camaros for sale. Are all 2.02/1.60 3927186 heads the same? If not, how do you tell the difference?
Re: What are the differences in 1969 3927186 heads
Allen-----
All 2.02/1.60 valve size GM casting #3927186 heads are the same (except for "dates", of course). However, not all GM casting #3927186 heads have 2.02/1.60 valve size. Many were made with 1.94/1.50 valve size. Externally, when the heads are mounted on an engine, you can't tell the difference between the "large" and "small" valve '186' heads. However, when you're shopping for a set of heads, as you are, which are off the engine, it's easy to tell the difference-----just measure the size of the valve heads.
