C1 61 Tranny Identification - NCRS Discussion Boards
  • Peter Cipriani
    I just purchased a 61 and I'm trying to identify the tranny in the car. Its all aluminum the main case T10-1C and tail is T10-7D. I cannot find a casting date? or part number?? Its difficult to see with the linkage etc. in the way. This car has a end of Feb. Build date. Any idea of its application.
    Thanks, Peter
    Re: C1 61 Tranny Identification
    Peter-----
    The T10-1C main case was used for both 1961 Corvettes and passenger cars built after about November, 1960 and right through 1962. The T-10-7D extension housing was used for 1962-63 Corvettes and passenger cars. So, the tranmsission may be a 1962 unit or it may be made up from parts from several different transmissions. Most of the T-10 parts are interchangeable.
    The code information and VIN derivative stamped on the main case would reveal a lot more about the origin of the transmission.
    • Loren L.
      • April 30, 1976
      • 4104
      Find the casting date on the psgr side of
      the tail extension and the assembly date on the driver's side stamped into the rear edge of the main case - Starts with "W" and probably ends with a "-#"
