C1 horn relays - NCRS Discussion Boards
C1 horn relays
  • Terry F.
    • September 30, 1992
    • 2061
    C1 horn relays
    What did the horn relay look like on the early Corvette? I remember them as Black bodied with an attachment flange. I remember that there were questions over the number of holes that should be in the attachment flange (2 vs. 3 holes?) How did they compare to passenger car relays? Where they the same? What year did they stop using them? Regards, Terry
  • Mike E.
    • February 28, 1975
    • 5134
    Re: C1 horn relays
    What year? Different part nos. and different mounts, depending on vintage.
    • Terry F.
      • 2061
      Re: C1 horn relays
      How do I get your email address. I can send you pictures. I don't think they have part numbers on them. Terry
      • Pierre J.
        • July 31, 2000
        • 193
        C1 Horn Relays
        Terry,
        There is one for sale on eBay now with a good picture. Check this link:
        Pierre # 34410
        • Terry F.
          • 2061
          Re: C1 Horn Relays
          The the next relay in production have a larger flange with 3 holes? I talking after 58. Regards, Terry
          • John M.
            • January 1, 1999
            • 1553
            Re: C1 Horn Relays
            Terry,
            The ones after 58 were 781 relays and came in two flanges, a 3 hole and a 5 hole. The flange was the same size and the # on the relay did not change, there were just two more holes betweeen the outer two holes. There are several for sale at any given time on Ebay. If it does not have the 781 stamped into the flange then it is not correct.
            Regards, John McGraw
            • Terry F.
              • 2061
              Re: C1 Horn Relays
              I went to ebay and looked around a bit. I found one that is similar to some that I have. It is item number 2441661448 . Mine look the same except have a black body and only 3 holes. Any idea what they were used on? Thanks for your help. Thanks, Terry
              • Terry F.
                • 2061
                Re: C1 Horn Relays
                Thanks, I will check mine out. Terry
                • Terry F.
                  • 2061
                  Re: C1 Horn Relays
                  Hey, I found a number on them. They are 775's so should be correct for 53-54 chevrolet? Am I correct? Terry
