C1 Rear Springs
  • Gary Azarian (36258)
    • June 1, 2001
    • 86
    C1 Rear Springs
    I noticed recently that one of the rear springs on my 59 was bent near the rear shackle. These are the original springs. Is there a service available to straighten and re-arch these springs. I would appreciate any feedback on the issue or recommendations for replacements
  • Donald Ling (31176)
    • October 1, 1998
    • 458
    C-1 Rear Springs
    Gary Smith in Memphis, Tenn. has been recommended on this board by the late Dale Pearman as a reliabe source for rearching rear springs. Sorry I dont have his phone number.
    Donald #31176
    • Dave Suesz
      No matter who does it...
      The spring should be annealed, re-arched, and then heat treated. As Dale explained it to me, if the spring is merely re-bent, it is weakened, and will bend again.
      • John Hinckley (29964)
        Re: No matter who does it...
        Eaton-Detroit Spring in Detroit ( www.eatonsprings.com ) is another fully qualified service center for spring re-arching; they completely disassemble the spring, inspect it for fatigue, and do a Brinell hardness test before going any further. Their process includes 1800-degree heat, re-cambering, oil-quenching, 1000-degree draw furnace annealing after quench, and shot-peening followed by another Brinell test prior to re-assembly.
        This process is particularly important for C1 rear springs, as the grooved raw material (SAE 5160 steel) is no longer produced by any of the steelmakers, so it's not possible to manufacture correct replacements from scratch.
          • June 1, 2001
          • 86
          Thanks for the information guys. I'll give Eaton a call.
