The passenger side dash pad on my 66 is a tight fit onto the fiberglass dash wishbone due to the two bolt studs that must drop into the wishbone drilled holes. While trying to install the pad, I bumped on the front top of the pad with my palm and inadvertently cracked the 38 year old vinyl in the region where I was bumping. it. The pad is now undergoing repair at the vinyl shop.
I plan to use a thin wooden stick and tap against the studs to drive the pad back and the studs into the holes whenever I re-install the pad. Any other ideas from experience here?
Dave Kitch
33108
Dave Kitch
33108
