C2 Trailing arm assy. torque - NCRS Discussion Boards
  • Eugene B.
    • May 31, 1988
    • 710
    Gents,
    Looking for info. about torque setting for the four 3/8-24 nuts that secure the trailing arm, spindle support, brake caliper bracket, and splash shield.
    Also need torque setting for parking brake pivot bolt.
    Gene
    Re: C2 Trailing arm assy. torque
    Gene-----
    The spindle support-to-trailing arm bolts are 30 ft/lbs. For the rear parking brake anchor bolt I have never found a GM-published torque specification. The bolt is 1/2-20 thread size and grade 8 material. I use 95 ft/lbs for this bolt.
    • Eugene B.
      • May 31, 1988
      • 710
      Re: Thanks, Joe *NM*
