C-1 brackets for front end nose support rod - NCRS Discussion Boards
  • Dave T.
    Infrequent User
    • August 31, 2000
    • 21
    I have a '60 with the front end nose support rod brackets off.(Corvette Central part # 30151). I can't remember which way they go back on. There are 4 holes with two wider spaced and two narrower spaced. Do the wider holes go to the top or bottom?? I have looked at two '62's and both of them had one one way and one the other way. Is that the way mine should be? Thanks in advance for any help.
  • Dennis A.
    • April 30, 1999
    • 1010
    Re: C-1 brackets for front end nose support rod
    Dave...
    I will check tonight for you, I believe the two wider holes are on top. also do not forget the Headlight Harness Clips.
    • Dennis A.
      • April 30, 1999
      • 1010
      Dave...
      I was incorrect, the two holes, closer together were on top... I looked at quite a few vettes before I glassed in new tabs and drilled the mounting holes. The AIM is not to clear on this assembly. The Clips do mount Inboard and I noticed during the Harness installation, that is exactly were they must be to clip the connectors.
