C3 Grey Phosphate with Sparkle - NCRS Discussion Boards
  • Mike South
    I have recently been plating C3 hood latches, male and female with grey phosphate from "Shooters Solutions" a company that caters to firearm enthusiasts. Althought the color of their grey phosphate is correct and the process worked well (heated the solution to 190-200 degrees F as per the directions) their grey phosphate does not have the "sparkle in the light" that I have seen on many of the finer examples of restored C3 hood latches.
    Can anyone recomend a vendor for Grey Phosphate that shows this "Sparkle in the Light" as stated in the C3 NCRS manual? Also, what proceedure is to be followed to get the aforementioned correct grey phosphate?
    Mike South
    NCRS Member #35686
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: C3 Grey Phosphate with Sparkle
    Mike, I can give you the name of another vendor, but I have no first-hand experience with their product.
    They are primarily suppliers to gun restorers (just like "Shooters Solutions"), but also have materials used for restoration of Harley Davidson and Indian motorcyles. My thinking was applications that work for motorcycles should also work for Corvettes. I only ordered their "black manganese" product, and not the H-D formula. It has the right chemical name (manganese phosphate) to produce the sparkles, but I haven't tried it yet.
    One result of your post was that I took another look at their website: I didn't see this before, but their grey parkerizing product is "grey OXIDE". I suspect this chemical may NOT produce the characteristic sparkles. The correct material for the grey phosphate with sparkles is zinc phosphate, but I don't think they sell that.
    Your experience should help some of us avoid the same problem. Thanks for sharing.
    Calvan Company
    • Tom R.
      • June 30, 1993
      • 4081
      It seems like in the last month or two we had a long thread on plating and finishes with several informative recommendatons. Use the archives to do a search and you should come across the motherload.
      Tom Russo
      78 SA NCRS 5 Star Bowtie
      78 Pace Car L82 M21
      00 MY/TR/Conv
      • Donald Brunswick
        I've used the kit Carl speaks of from Calvan with good results.
        • Mike South
          Thanks to all of you for your help, I will also check the archives.
          Mike South
          • Chuck S.
            • April 1, 1992
            • 4668
            Don, which kit did you use, the "regular" black & gray combo kit or the "Harley Davidson" combo kit? I felt it was the same chemicals in different strengths, and ordered a single bottle of black manganese for trial.
            • Donald Brunswick
              Chuck I bought the Large Black Manganese Parkerizing Kit from them. As with anything like this a little practice and they really turn out good IMO. I want to thank you for finding them, I bought the kit after you posted the thread here a couple of months ago.
              donald
