I have a 1970 LT-1 with a May build date and am in the process of trying to make sure I have a correctly dated smog pump. I have the Judging Manual, which helps, but want to make sure. I currently have two smog pumps both bearing casting numbers 7801149. They are also coded from left to right as follows: Pump 1: 57 D20
Pump 2: 306 D59
Also, can you please clarify what color/finish the cast smog pump mounting bracket should be for my car. One that I have is black while the other is orange. I would also like to know whether the pulley for this pump can be painted black without a significant point deduction. My pulley is from Paragon and came that way (black).
Thanks in advance for the assistance.
Pump 2: 306 D59
