Once again I come to the well of knowledge. With the original rear springs installed, I seem to have about 3 inches of driveshaft yoke showing with weight on the rearend (though sans bumpers and interior). I would expect an 1 1/2 inches showing. A rough measurment indicates that the present installation has the longer portion of the spring to the front, measured from the centerline of the axle. I found a post in the archives that stated a '57 spring had a 1 1/2 inch offset (clamping bolt) to the rear, thus the front of the spring longer. Is there a front and rear to the main leaf springs and what is correct.
C1, '58 rear springs
