Short throw Shifting - NCRS Discussion Boards
  • Gary Bishop
    Bill and Jack: Can a '62 T10 be adjusted to short throw?
    Re: Short throw Shifting
    Gary, don't have a '62 AIM and experience is limited to Muncie. Check out the shifter arms and see if they have dual mounting holes (high and low). If so, it's like Bill said, move the connecting rod from the shift lever to the lower hole for short throw and 'play' with what you get.
      • Bill Clupper
        Gary, I did it on a '58 one time, but you have to make new holes in the arms. This requires either a high quality drill & drill press or access to a toolmaker buddy with an EDM setup in his shop. It works the same as the '64-up setup, but the extra holes aren't provided.
        • Bill Clupper
          • Gary Bishop
            Thanks Guys. I will continue to stir the pot the old fashion way.
            • Gary Bishop
