022 master cylinder - NCRS Discussion Boards
022 master cylinder
  • Robert M.
    • April 30, 1999
    • 415
    022 master cylinder
    I recently found a 022 master cylinder for my 61. All numbers are correct on it per the judging manual, but the 022 is the same size as the rest of the casting number "5456". I have another 022 the needs to be restored and it has the larger 022 cast number. What is the difference and are they both correct?
  • Mike E.
    • February 28, 1975
    • 5134
    Re: 022 master cylinder
    Rob--
    The larger 022 is correct for your 61. The smaller 022 is earlier, starting, if I recall, in 57.
