I am in the process of replating the vent frames and replacing the rubber seals around the windows. I have the inside of the doors taken apart. I thought this would be a good time to make adjustments on the doors. The passenger door closes perfectly. The drivers door has always closed very hard. After carefull inspection of the drivers door it appears that the door strike hits the latch too high. The strike is the frame part the latch is the door part. The fix would seem to be to raise the strike or lower the latch. The strike is as high as the factory holes will adjust to. The latch does not appear to be adjustable. What am I missing? Do I have to adjust the entire door? When the door is closed the lines look good.
If I have to adjust the entire door what is the proper proceedure. I don't want to make this problem worse.
As always thanks in advance for the help.
