If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
Having repaired several damaged areas on the firewall (ex-racer), 245 HP, SN 8490, I apparently have glassed over the thru hole location for the pass. side hood release cable. Could someone give me the location with two approximate reference diminsion point. Thanks
Terry: if car apart(no firewall insullation attached) look on cockpit side of firewall for glassed over area. Otherwise , wait till a 58 owner responds to your post. good luck, mike
Unfortunately, I have the firewall insulation and all the heater stuff installed. I'ved pulled as much as I can without taking things apart. I don't know where to look.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
