C1 Driveshaft (Texture?) - NCRS Discussion Boards
  • Tom Spurgeon
    I'm in the throws of sandblasting anything that gets near me (haven't seen my wife for a while). The most recent item is a driveshaft that was suppose to be from a '60 vette. After uncovering layers of mud, grease, road-tar and rust, I've found an interesting pattern (texture) at the metal's surface. Does anyone know if C1's had a texture to the driveshaft? ...I hope they did, this pattern is pretty neat! Thanks for your help...
    Tom
  • John M.
    • January 1, 1999
    • 1553
    Re: C1 Driveshaft (Texture?)
    Tom,
    Every C1 driveshaft that I have ever seen was dead smooth and the ends had the Spicer name cast into the ends.
    Regards, John McGraw
      John and Tom----
      I would expect them to be very smooth, too. The tube section of these C1 driveshafts was extruded tube which was neither sand blasted nor shot-peened. Extruded tube is quite smooth.
      • Ted L.
        • May 31, 1999
        • 101
        Tom,
        My '60 driveshaft had a texture too - it's called pitting and its caused by rust. I sand blasted and painted it and its still not as smooth as it was new.
        Ted #32350
