66 BB PCV - NCRS Discussion Boards
66 BB PCV
  • Brian J.
    • August 31, 1999
    • 70
    66 BB PCV
    I would like to know what is stamped into the correct PCV for a 66 BB car? Any help will be appreciated
    Re: 66 BB PCV
    Brian-----
    It depends which engine it is. Either way, I can tell you exactly what's stamped on the valve:
    L-36
    AC SPARK PLUG
    TYPE C.V. * 691C
    There's an additional SLIGHTLY larger than the period "dot" in the position represented by the (*), above.
    Early L-72
    same as above
    Later L-72
    AC SPARK PLUG
    TYPE C.V. * 736C
    There's an addtional SLIGHTLY larger than the period "dot" in the position represented by the (*), above.
    • Brian J.
      • August 31, 1999
      • 70
      Thanks Joe "NM" *NM*
