C1 Electric Wiring Components - NCRS Discussion Boards
  • Richard H.
    • March 1, 1985
    • 241
    Any suggestions regarding sources for purchasing correct individual connectors, clips, etc. to restore the electrical system? Lectric Limited only has the complete wiring and harnesses systems.
    • May 31, 1974
    • 8365
    Re: C1 Electric Wiring Components
    if you don't want to go the repro route and want to rebuild/restore your original harness, simply take it out, then apart, then get a wiring diagram(electric limited) and evaluate what's still there and what's missing. i'm not aware of a source for the various terminals you may or may not need . i simply cruise the salavage yards for 50's ,60's and 70's GM harnesses , remove them from the old caddy, olds or pontiac , go home, dissect the needed part from mr oldsmobile etc, then transplant it back into my "injured" orig harness. takes a bit of time but i rest assured i've got the right terminals, connectors, etc and also rest assured the wire to terminal connections are soldered properly if i've done the soldering(have bought repro harnesses that didn't always have continuity).mike
    • Joe R.
      • July 31, 1976
      • 4547
      Re: C1 Electric Wiring Components-Mike
      Mike,
      You are being so nice and diplomatic. Eagle wiring of Tennessee has some of the connectors but not all. You might want to check with them. He will probably be in Florida and always sets up at Knoxville in the Spring and Fall.
      JR
      • Richard H.
        • March 1, 1985
        • 241
        Thank you gentlemen for the suggestions.
