Need help with installing the main harness. When and how will I get power to the other harness?
64 coupe
Re: 64 coupe
Assuming battery is connected, when engine bay harness red gauge 12 (or gauge 10 for air cars) is connected to starter solenoid (along with +ve bat. conn.) there is power, via return from horn relay junction, to firewall multi-connector, which supplies power to ignition switch. From there, power feeds the main under-dash harness, which connects via a multi-connector to the rear wiring harness.
Minor variation for air cars, where blower motor, speed resistor, A/C relay, compressor clutch, and air controls on dash are fed from an additional wire on horn relay, and not from the ignition switch.- Top
