What lubriation should be put in the bearing? When I got it apart the Lube was all dried up.
C-1 Third Arm Bearing-1959
Re: C-1 Third Arm Bearing-1959
Jerry,
I put a new double sealed bearing in them and leave any additional grease out.
With the sealed modern bearings that are made today, There is really no reason to ever lubricate them. Don't forget the foam rubber seal between the third arm and the mounting bracket, it keeps a lot of water out of the bearing.
Regards, John Mcgraw- Top
