H2O 3 bolts 1 stud? - NCRS Discussion Boards
H2O 3 bolts 1 stud?
  • chester
    H2O 3 bolts 1 stud?
    As with any restoration you find out many things when you receive new parts. i got my new bolts to put on the new (rebuilt original) water pump there was three bolts (same size) and a bolt/stud. Hummm, I marked the ones i took out ant ther was no stud there??? Where does the one stud go if you look straight at the motor? and what's if for?? Pully? bracket? thanks jc
  • Brandon K.
    • April 1, 1997
    • 474
    Re: H2O 3 bolts 1 stud?
    Chester, What year and engine size do you have?
    • Brandon K.
      • April 1, 1997
      • 474
      • Bill Baird
        Chester,
        You didn't say what year and engine you're talking about, but my '75 L-48 (small block) has three bolts and a stud holding on the water pump. The stud is on the driver's side, upper hole (I believe), and holds my alternator brace.
        Bill Baird
        • Bill Baird
          Chester,
          Bill Baird
          • chester
            It's a 68 427/390 L36, I just don't recall any stud that I took off. thanks if you've got info!! jc
            • chester
