Found a source for the High Beam Headlite Relay Kit which whenn installed will allow for all four lights to work when High Beams is on. Stylinconcepts.com . $59.90 total. REALLY MAKES A DIFFEERENCE FOR OLD EYES> mike
'03-upGM F/s pickups and suvs
you can do the same thing for $4.95 and some wire
just buy a fog/driving light relay at the auto parts,trigger the relay with the hi beam headlight wire and run a 12 ga fused line from the red terminal in the altenator thru the contacts on the relay to the low beam wire. that way you get a full 14.5 volts to the low beams. if you use a digital volt meter at the headlights you will see that that there is only 11 volts because of the resistance of the wire. i have been doing that since the 4 head light systems can into being.- Top
