Tank Sticker; Dealer ID for '71 - NCRS Discussion Boards
  • Charlie P.
    • July 31, 2003
    • 260
    The tank sticker on my '71 appears to be part of a carbon paper stack-blue print on the typed-in info and blue carbon on back. Is this kosher? I have never actually seen one before. Also, anyone familar with zone 15 or and/or dealer 628 in early '70s? I couldn't get in from the data base, unless I'm doing something wrong. THANKS
  • Brian McHale
    Re: Tank Sticker; Dealer ID for '71
    Send a copy to AlGrenning@aol.com he may have info on your dealer.
    • Dave S.
      • August 31, 1992
      • 2918
      Charlie,
      You have what sounds to be a correct Corvette Order copy for 1971. You should also notice the VIN in reverse toward the bottom of it.
      • Charlie P.
        • July 31, 2003
        • 260
        Yes, Dave, I do see that reverse serial #. Also, the last three digits appear hand-written, top right.
        • Warren F.
          • December 1, 1987
          • 1516
          You have described a correct Corvette Order Copy sheet for a '71 year.
          • Dave S.
            • August 31, 1992
            • 2918
            The handwritten 3 numbers are the job number which was assigned on the assembly line. There is a lot of history on this in the archives. It is some coincidence that they match the last 3 numbers of the VIN as most do not.
            • Charlie P.
              • July 31, 2003
              • 260
              Dave-I found the same three-digit # on the underside of one t-tops. I'll check the archives.
              • Warren F.
                • December 1, 1987
                • 1516
                Charlie:
                The handwritten 3 digits are also my vin numbers as well.
                • Tom R.
                  • June 30, 1993
                  • 4081
                  Charlie:
                  The t-tops were placed on a fixture over the windshield and followed body as it went through paint, ovens, blackout and trim assembly. They were matched to the body so it is not surprising the body shop job number appears on them as well.
                  Tom Russo
                  78 SA NCRS 5 Star Bowtie
                  78 Pace Car L82 M21
                  00 MY/TR/Conv
                  • Dave S.
                    • August 31, 1992
                    • 2918
                    I bet you will find it under the passenger side splash pan as well. Its funny how corvettes keep on giving(once in a while)
                    • Richard K.
                      • April 1, 1988
                      • 207
                      Brian is right. Send a copy of your tank sticker to Al Grenning. But for now, I can tell you that Zone 15 is Philadelphia.
