C1 57 fuel gage - NCRS Discussion Boards
C1 57 fuel gage
  • Verle R.
    • March 1, 1989
    • 1163
    C1 57 fuel gage
    The fuel gage has started fluctuating wildly when the tank is something less than full. I know it did not do this before.
    I assume the damping is in/on the back of the gage, what should I look for.
    Thank you,
    Verle
  • Ed Jennings
    Re: C1 57 fuel gage
    First check the sending unit in the tank and the connections. Also, it wouldn't hurt to add a dedicated ground to the sending unit flange.
    • Roy B.
      • February 1, 1975
      • 7044
      Re: C1 57 fuel gage
      The rheostat inside the sender can get shellac build up on the wires, which in turn you loss a ground connection, but can be opened and cleaned if your problem is not a ground wire or bad gage.
      • Verle R.
        • March 1, 1989
        • 1163
        Re: C1 57 fuel gage
        I installed a new tank and new sending unit last spring. It has worked properly until recently.
        I will check the ground from the sending unit.
        The fluctuation is directly related to the sloshing of gas in the tank. If I turn the switch on after the car has been setting still for a while the gage is steady.
        Verle
