I had a brain fart and thought that i would install the later 73 rubber body mounts on my 69 to improve sound , vibration and lessen the possibililty of glass cracks , well i chickened out and just put the aluminum spacers as original but the question is now i mixed the mounts up they came in 2 boxes 4 #334756 black mount and 4 # 334755 with some white around the mount to ditinguish between the two different ones for a convert . the problem now is the two differnt ones , lets refer to the female there are 4 that are more rigid or less pliable than the others does the soft rubber female belong with the white stripe or the black , who knows there body mounts?
c3 69 body mounts
Re: c3 69 body mounts
Kelly I have all the 73-75 rubber GM body mounts in original boxes to convert my 68 convertible, have had them for about 15 years. Give me a couple days to get back to you. Saw your post last night and forgot to locate them today. Contrary to what is repeated to me I do know where to find things in my garage. I will look at them tomorrow.- Top
Kelly cushion #334755 is the more firmer rubber and mine have a white coating on both pieces. Also there are numbers on my pieces. The taller piece has BM and 25 on the side, the other one has 53 397109.
The other cushion is #334756 and is the softer rubber and has no white coating for identification.
Without consulting my written information, the white coated cushions are used in body mount positons #2 and #3.- Top
