The front end of my '65 Coupe is about 3 inches to high. The coil springs are the original(and correct) ones (small block). They are also positioned correctly into the shock tower and lower A-arm. I have done a frame off on this car. I had heard somewhere not to tighten up some of the chassis as the chassis will settle when the body is lowered onto it. I tightned up everything to specs on the chassis before the body drop, my mistake? Could this be causing the height problem, and if so where do I need to adjust (loosen) the chasis to allow it to settle to correct height. And is there some other way to lower the front end? Please note, the bumpers, grill, windsheild, and seats are not installed, but I don't think that the installation of these components would make the car go down 3 inches, could it? Any input would help.
Jeremy Hedges
Jeremy Hedges
