Is the rear end in an '84 a dana 44? NM *NM* - NCRS Discussion Boards
  • Ralph Harlan
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: Is the rear end in an '84 a dana 44? NM
    A 4+3 should be.
    • Ralph Harlan
      Thanks, mine is auto. All my local Chevvy dealer can tell me is that the factory ratio should be 307 (unless it is a 331 - which according to his book has the same ref #) and it is a GM.
      • John M.
        • January 1, 1999
        • 1553
        Ralph,
        I believe that all automatic cars had a Dana 36 and all manual cars had a Dana 44.
        Regards, John mcGraw
        • Jim T.
          • March 1, 1993
          • 5351
          Ralph don't know specifically about your 84, but my 85 has a label located in the compartment behind the drivers seat that is visible when you open the compartment. This label lists the codes my 85 has. You can also spend a few dollars and get a printout from the Corvette Museum. The Corvette plant gave all the retained and stored information to the museum for this purpose.
