I recently tried to change the fan belt on my 66 327 L79 with a ZIP repro belt. The new belt was too long as I had to move the alternator all the way to the end of the bracket, and it was still too loose. The old belt measured roughly 53", while the ZIP repro was 54". I have single groove pulleys and ONE belt. My car has no ac, ps or smog equip.
I recently read that the specs for a L79 is listed as having TWO belts and double groove pulleys on the crankshaft and water pump pulleys. Is this correct? If so can a L79 motor be fitted with a single groove pulley set up and ONE belt? I ask this because my motor is supposed to be a L79 but I have ONE belt. Lastly, what were the advantages or reason of having TWO belts if indeed the L79 came with them.
My car is by no means NCRS spec, but I would like to change my belt set up if it's wrong. Any insight would be appreciated.
MC
MC
