'67 CROSS SHAFT PLASTIC SEATS - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    I put 1 plastic seat on each side of the clutch stud that attaches to the frame. I have 2 left over. I assume 1 goes between the engine clutch stud and the cross shaft. Where does the other one go?
    Re: '67 CROSS SHAFT PLASTIC SEATS
    Rob -
    You now have two extras - the plastic seats only go on the stud at the frame end; no seats are used at the engine stud end.
    • Rob A.
      • December 1, 1991
      • 2126
      Thanks, it's usually not a good sign when you have left over parts....
      • Rob A.
        • December 1, 1991
        • 2126
        The assembly manual doesn't show any lubrication to be applied to the engine pivot stud. Is this because the cross shaft is already filled with grease when installed?
          Probably an oversight in the manual - I'd grease the engine stud end; I know the engine end of the shaft was greased on the old Chevy II V-8, because I greased and installed them on the line back in '64
          The engine side stud should have a rubber or fiber washer/seal on it to keep the grease inside the end of the shaft (which is why it's called out as a "stud assembly" in the A.I.M.
            Rob-----
            IN PRODUCTION the ball studs on either end were greased as John described. Consequently, it was not necessary to fill the cross shaft with grease. In SERVICE, there is no way to apply grease to the ball studs without removing the cross shaft from the car OR injecting pressurized grease at the fitting/hole in the cross shaft. Usually, folks find it easier to grease the latter way rather than removing the shaft from the car.
            Also, although the nylon seats are only used on the frame end of the shaft, there are TWO seats used at this location on either side of the ball stud.
            • Rob A.
              • December 1, 1991
              • 2126
              Is there one plastic seat on each end of the frame side ball stud or two? I have a rubber seal for the engine ball stud that is marked as going between the stud and the block, is this correct?
                Rob -
                As shown in UPC 7, Sheet C1, the frame end uses two Delrin seats; seat goes in first, then the stud, then the second seat, then the spring retainer, then the seal washer, then the frame bracket, special lock-tab washer, then the nut. At the engine end, the rubber seal goes on the stud, up against the engine side of the ball. Grease everything up well as you assemble it.
                • Rob A.
                  • December 1, 1991
                  • 2126
                  Thanks, I have that diagram, just wanted to be sure while things are still easy to get to.( I thought someone mentioned a seal where the engine ball stud enters the cross shaft to keep the grease in).
                    Rob -
                    The rubber washer up against the engine side of the ball serves that purpose - crude kind of seal, but that's the way it was.
                    • Timothy B.
                      • January 1, 2004
                      • 438
                      I have been looking for the seal that goes on the engine side ball. Is it different than the felt seal on the other side?? Can you recommend a supplier who sells the right part, as I have been looking...
                        Tim -
                        LICS has it - item #28-07B, $2.00.
