I'm working with a number matching 1967 Corvette.
327 350HP with a Muncie M21 Tranny and 3.55 rear end. The casting numbers on the transmission are correct, and the stamp date code and VIN numbers are also correct. Here is the problem: The ID tag that was on the transmission is: 3890563 I think the correct tag number should be: 3880853 (M21 Close Ratio L79). I was unable to find anything about 3890563 tag number. If someone swapped tags, this number should still be a valid "Muncie" part number, yes? I can't find any info on it. Any help?
Thanks Ken
Thanks Ken
