My restorer pulled the body off of my 69 corvette Friday. Today I went down to look at the car. As an after thought, I decided to look for the shims from the car. When I got done, it was apparent that the car only had one shim under the #4 mount. All others did not have any. I looked at the aluminum spacers and all but one (which is the one with the shim) had tape over them from where they were taped to the frame with no shims. I also did not observe any shim marks on the frame. The one that had a shim I did not see any mark and I believe that that is because of surface rust probably erased the mark.
Now the question: How unusual is it to have a vette with only one body shim? (The perfect frame??)
Second and main question: When the manufacturer had no shims to add onto the frame, did they mark it with a "0" or did they leave it unmarked?
Another question I have is, if it goes back on the body and still does not require shims and I decide to not mark a "0", what will NCRS say if there are no shim marks on almost the whole car!! (I hate to have a car with a bunch of zeroes all over it!!)
Of course, when the restorer puts the body back on the car, he will reshim it as needed.
Any comments would be greatly appreciated as I think that I do have an unusual frame. One last thing, the body has never been off of the car and everything was aligned perfectly.
