I just came across a carb Holly carb that I have never seen before. It looks like a Holly with no fuel bowls. I found the vent in the center of the carb and it appears that the fuel bowl is molded between the venturies. There is a gasket between the throttle plate and the main body unlike a carter or Qjet. The main body is one piece without any vertical gaskets, just two horizontal gaskets, one below the main body mounting the throttle plate to the main body and one above that mates the air horn to the main body. The secondaries are activated by a simple rod on the driverside and it does not seem to have a choke lock for the secondaries. The secondary shaft on the passenger side is not connected to anything. It was mounted on a spread bore manifold, but the primaries and secondaries are the same size, but they seem to be spaced further apart then usual. I know its a Holly only because the word HOLLY is molded into the top between the two secondaries. There does not seem to be any other numbers on it. It also fells very light.
I showed it to the local speed shop and they never saw one before either. Am I just not that old or just to young to have seen one of these.
Tom S
Tom S
