Colleague Restorers,
Just bought myself some radiator seals to install my new radiator properly. I'm just wondering what the correct procedure is to install the radiator using these seals (are they glued and if so what type of glue should be used). I've received 2 side seals, 1 bottum seal and some triangular top seals.
I also received the needed drain cock and rubber drain hose. The lower shroud (still to be paint prayed) with the needed bolts (no nuts). I still need the proper bolts and nuts for the upper shroud (which itself is still usable), which are diffecult to find over here (due to the non-metric measures).
I have to reuse the old upper hose since it seems almost impossible for me to get the right hose (I have a straight thermostat housing). The new lower hose seems to fit just fine.
greetings and merry Chrismas,
Rob Musquetier.
The C1 1959 Corvette Restoration Project
Rob Musquetier.
