1967 Shoulder Belt Pocket Screws - NCRS Discussion Boards
  • Paul L.
    • November 1, 2002
    • 1414
    What screws are used to attach the shoulder belt buckle pocket to the bulkhead behind the seats?
    • May 31, 1974
    • 8365
    Re: 1967 Shoulder Belt Pocket Screws
    Phillips head trim screws. mike
    • Paul L.
      • November 1, 2002
      • 1414
      Thanks Mike. The Wife got me shoulder belts for Christmas and I wanted to get the install correct!
        • May 31, 1974
        • 8365
        Paul: did your 67 have the metal reinforcement plate with captive nut on each rear wheel well tub to mount the shoulder harness. what's vin (just a range) if it did or didn't have the plates. Mike
        • Paul L.
          • November 1, 2002
          • 1414
          Mike,
          I went digging under the carpet last summer to see if those plates were installed at the factory. And indeed they were (see pic). The VIN is 10,5XX, around February 1967.
          • Mike Arteaga
            I just did this job on my 67' There was a plastic cap inside the nut to keep water out of the interior. It came out easy but the nuts were badly corroded so I ran a tap through them and then allen screw went right in. Good luck!! Mike Arteaga
