Hi Guys
I was told by the previous owner that he changed the clutch/flywheel and bellhousing after it came apart and broke the bellhousing thirty years ago,I found the barely used clutch disk that I changed when I rebuilt the engine in 1988 and its a 10.4" .
I checked the archives and believe it should be a 11" clutch/flywheel on the
67 427/435 is that the same for the 390 and 400.
Do you know what the part number for the flywheel would be and the casting number,so I can Identify it ,I can dig out my spares ,as well as a friends
I'd may change it,if I can find the bellhousing, its #3840383 for 10.4? and should be a 3899621 for 11" and the trans tailhousing is #429 drivers side speedo and should be a #584 pass side speedo.
Never checked it before,am I on the right track
Frank
Frank
